I think that looks really good- gonz
You better throw the junk somewhere, but do not use your truck with free wheeling hubs. I once used them and later had to rebuilt the trans! The bearing is not made for that. And noise will not be less. So, forget it. I know what I'm talking about. I own a M715 since 26 years and drove it for almost 100,000 miles.
Wolf
What are you talking about Wolf-dose, manual hubs junk? Toasted your trans? I don't think the hubs had anything to do with your trans. What bearing? I'm sure you know what your talking about, but I'm not too sure your right.
Wolf-Mann, the hubs merely let the front wheels spin without turning the front axle shafts, front differential and front driveshaft. With fewer parts spinning, you have more power available and less wear and tear on parts. I'm not sure how this could affect the transfer case or transmission. Could you elaborate on what your experience is? Danke!
If you post in german, we have a member or 2 who may be able to translate...
Was ist mit seinem Englisch falsch?
They look great! were can I get a set?Just what i need another project
Good luck on the Warn Hubs, they are hard to find. I got lucky. You can get the selectros pretty easy.
