So I have a 360/4 speed/tcase out of a 1974 J truck that will be swapped in
What motor mounts do I need to get? I'm fine with modifying a bit, but would like to start with something close.
Thanks!
Thanks!
so I'm installing a J truck engine/trans/tcase as 1 unit
not using the stock divorced T case
will I have driveshaft length problems?
What transmission/tcase are you going to use? That will help people who did the same swap let you know what they did for drive line adjustments.
360 / T18/ D20
I have both the J truck and the M715 driveshafts
was hoping the rear driveshaft wouldn't be too long
thanks
changing gears....
gonna swap in a 2002 5.3 LS and a 4l60 and keep the NP200
does anyone have an example of what they did for Tcase lever brackets with an engine/trans swap?
thanks
In the course of this engine swap, I'm upgrading to a pedal mounted brake light switch.
I want to remove the pressure switch.
Anyone know the threads for a plug where the pressure light switch goes?
I thought it might be 1/4?, but not 100% sure.
I went with a pedal mount as well. I think that I browsed Napa until I found what I was looking for.
thanks. I'll start with that plug size and go from there.
any pics of your pedal mounted setup?
I will give it a look. It might be easier to snap a picture. Heading out for business for a few day, but will try to get it on the weekend.
