I have the regular round front turn signal light housings. Does anyone know for sure if the newer not-quite-round lights will still fit in the same spot on the M715? Any modifications needed?
mcinfantry: do you have the new LEDs yet??
Stan
Stan
i dont have my lights yet, maybe today....
i dont have the truck either, so im not too miserable. ive been told the newer semi round fit w/o modification.... ill let you know, though
The rears no problem...the fronts might need a little trimming on the sheet metal to get them in...Also are you using LED fronts? You might need a space to flush them out with the grill...Not sure but is possible if they are thin like the rears.
i bought the buckets for both....
Lee, i ordered aused pair from memphis equip. They were about $45.00. They were 24v,so i went to auto zone and got some bulbs ground down one of the tits on each bulb so they would fit in the socket. later matt
