NICE!!
Like that shirt too!!
NICE!!
i noticed i had the FE shirt on after i got home and loaded the video on my computer. quite the coincidence as my fashion planning is as deep as what is on the top of the pile of shirts/pants/etc.
ryan
Same here...but most of my shirts are Zone stuff these days!
installed the rear driveline today and got all the lights to work. i have a few more wires to figure out and decided what i am using and what i am not, then loom it all and be done with that nightmare. should at least get to move it under its own power tomorrow
http://i94.photobucket.com/albums/l8...15/m715413.jpg
http://i94.photobucket.com/albums/l8...15/m715414.jpg
generic turn lever i got at napa
http://i94.photobucket.com/albums/l8...15/m715416.jpg
ryan
The Signal Stat 900 is the exact switch I used in my M715. With some OD it looks almost stock. It wired in perfectly with my harness that was a Painless knock-off. The only thing I had to do was to add a second flasher unit for the Hazard feature. The wiring harness kit only came with a single flasher for turn signals. No big deal, only three extra wires to run. They also make another switch that has the hi/lo beam incorporated into it as well. I may change over at some point. My floor dimmer switch always seems to get packed with mud after a wheeling trip.
If I have any complaint, its that they aren't self cancelling. Kinda nice for those 40 MPH jaunts down the highway with a mile of cars behind me and the left blinker on.:D
haha
i don't know how many semi trucks if seen doing that :)
i have seen them before with a goofy rubber wheel that rides on the hub of the steering wheel and cancels the signal. i can't remember where or what it was
this one wired in perfectly. i had two flashers in my harness and all i had to do was plug and play. i have a couple things to figure out today with the guages and i think i will go ahead and wire in the 4wd switch too. headed out soon to do that. i will report back later.
this weekend proved much more fruitful than most.
http://i94.photobucket.com/albums/l8...th_m715418.jpg
http://i94.photobucket.com/albums/l8...th_m715419.jpg
sorry about the rowdy exaust noise. that is still on the list
4x4 switch is busted, so the light is always on. i need to figure out why it will crank with the switch off, and why the turn signals function when the switch is off. i think i also need to get matched senders for the guages. outside of a these little things i am pretty happy with it all
The turn signal units with cancellation "the rubber wheel" were actually stock on many Jeeps in the late 50s to the early 70s...
Also congrats on the initial motivation of the truck........
Nice job there.
I take it the dog has been around enough vehicles not to get run over........
Scott
