5" exhaust welded up and hung
[IMG]hthttp://i87.photobucket.com/albums/k1.../exhaust-1.jpgtp://i87.photobucket.com/albums/k146/tndonor/IMG_0116.jpg[/IMG]
http://i87.photobucket.com/albums/k1...r/IMG_0117.jpg
Rolled and brushed some bed armour in the cab and lower cage as Ill be stepping on them and can use the traction Im sure
http://i87.photobucket.com/albums/k1...r/IMG_0129.jpg
http://i87.photobucket.com/albums/k1...r/IMG_0130.jpg
Seats are in for the final time! Man the cab shrunk. Cage is also done
http://i87.photobucket.com/albums/k1...r/IMG_0132.jpg
http://i87.photobucket.com/albums/k1...r/IMG_0131.jpg
http://i87.photobucket.com/albums/k1...r/IMG_0133.jpg
And under the battery box lid......
http://i87.photobucket.com/albums/k1...r/IMG_0138.jpg
This is where the Oasis compressor will live. I have some more venting to do. It already has the hole in the bottom for the power cables and air line to exit the cab underneath.
OX Locker cable is in and the location has been worked out.
Tomorrow is finish locating the steering wheel and mounting the floor plate seal/cover thingy around the column. Also mount the clutch master to the firewall.
I switched directions on the ps pump. I yanked the stock ps pump and put in a zf hydraulic pump. Went from 1 gpm to 4.5. Also went from metric ps box fittings to -6. Because of this I has to relocate the radiator up to accomodate the 90 degree fittings. All that is left is to make the ps hoses.
Hydroboost is mounted to the firewall ofor the final time. May get the hoses done tomorrow as well. Im not sure where I am going to put the ps cooler at. Space is becoming premium. I have an idea but wasnt the front bumper on before I commit to it.
Bought 5 gallons of gear oil to fill everything. Have 4.5 gallons of collant to put in. Ill stop there and hope I get this done this weekend.
Once again, great progress. I love the 5" exhaust, i'll bet that will sound good
Your truck is coming out really nice!! Can't wait to see the finish product!
Very nice! I only started on page 4, liked the 6bt and trans but then all the extra metal you've added... You're gonna NEED IT:)
I'll venture to say that you've added about 700lbs besides the drivetrain:lol:
About what did you spend on seats like those?
E
I hope no varments were hurt in the making/breaking of the rockers..:lol:Quote:
housing a rodent and babies
