This is just an amazing build, thanks for posting, it's very inspiring
OMG this a a very very nice build M715 congrats :D:D:D
thanks .... and still not finished !! Been working hard the past two weeks !! I will updated the pics next week end
Hey buddy i am planning a j10 build was wondering what kind of motor mounts you used and what kind of mods did you have to do under the hood on the body??? Thanks alot
stock first gen cummins engine mount ..... and no mod at all under the hood for the body .... but you need to run electric fans .... If you want to keep the stock mechanical fan ... cut into the rad support and move the rad up front a good 2" .... and everything will clear
I just went to my US adress this morning and i received two defrost vent from VPW and my twin stick and handbrake boot .... Since i remove my injection pump ... i will be able to bring my power back because i can lower the idle now the screw is no longer jammed. More pics to come by this weekend
http://www.rockcrawlerquebec.com/kam...hifterboot.JPG
no pictures but here's some updates ---)
I have heat ... lot of heat ... maybe even too much !!
Working defroster
Received an HID lighting kit for my birthday ... 55 watts low and high H4
Freshly installed non oem wood sides ... just need to be painted tomorrow
New project ..... 4" snorkel !!
Forgot to tell the the truck is now back on the road .... I tried the rear locker doing a nice 360 in front of the driveway !! That truck is sick ... i never taught it could be doing a 360 so easilly !! Next summer it will receive new injectors ( 80 hp ) and i hesite between tranny upgrade ( shift kit ) or manual swap !!
What other mods have you done to the motor besides the 3200 governor spring, fuel pin, and turning the fuel screw?
Nothing more then that .... the gov spring is not even installed because i doesn't need it ... running 70mph with that truck is more then enough. Next summer will add 80 hp injectors and finished my intercooler setup. Since here we are having 30 and down degree i dont need the rush to instal the new setup that will consist of a new bigger radiator and air intercooler instead of the water setup i was supposed to install.
