http://i87.photobucket.com/albums/k1...r/P5201206.jpg
http://i87.photobucket.com/albums/k1...r/P5201202.jpg
http://i87.photobucket.com/albums/k1...r/P5201203.jpg
Your truck is looking great. If I had the finances (approval from better half), I would have the same set up in mine. Can't wait to see the finished product.
Cab went back on with mew body mounts.....fisgured what the heck while it was stripped down that far
http://i87.photobucket.com/albums/k1...r/P5211207.jpg
I had bought a mojave heater for the truck sometime ago. I didnt like how I would have to have mounted it with the limited outlets and options it gave me. I ordered a unit made by Danhard. In addition to the four front outlets, the defrost outlets (2) are on top which is perfect. I picked up some NOS defrost ducts for the truck. This heater allows you to completey isolated the unit from the coolant so you the unit itself will not be hot when I dont want it to be......summer etc.
http://i87.photobucket.com/albums/k1...r/P5261208.jpg
http://i87.photobucket.com/albums/k1...r/P5261210.jpg
http://i87.photobucket.com/albums/k1...r/P5261211.jpg
http://i87.photobucket.com/albums/k1...r/P5261212.jpg
http://i87.photobucket.com/albums/k1...r/P5261213.jpg
Currently the truck is getting the seat mounting and in cab configurations done. I have a panel from 12v guy ordered to include incab which controls front and rear, keyed ignition, 7 toggles with circuit breakers, and battery isolation monitoring/control.
All guages for the dash are ready to the interior when it goes together (speedo, oil, water, boost, pyro, volt)
Will be building a center console to house the electrics. Once this is a bit further, the cage will be bent and seats mounted.
Update time. The roll cage is in (minus the head bars). Havent decided where I want to locate those yet. And its nice to still be able to stand up in the cab. Seat mounts are welded into the roll cage.
http://i87.photobucket.com/albums/k1...r/IMG_0043.jpg
http://i87.photobucket.com/albums/k1...r/IMG_0092.jpg
http://i87.photobucket.com/albums/k1...r/IMG_0044.jpg
Hugs the contour of the windshield very nice
http://i87.photobucket.com/albums/k1...ageprofile.jpg
Got the oil drain for the atmospheric turbo in. It is a 3/4 npt to -12 AN hose.
http://i87.photobucket.com/albums/k1...nor/drain1.jpg
http://i87.photobucket.com/albums/k1...nor/front2.jpg
I have the gauges in. There is a speedo, pyro, boost, oil, and water.
http://i87.photobucket.com/albums/k1...nor/gauges.jpg
http://i87.photobucket.com/albums/k1...nor/inside.jpg
