No black stars on any vehicles in our Pershing Missile unit. And we had lots of various types.
Thank you Don. And thank you for the FABULOUS pictures!!!
I had a 1967 that was painted 383 carc (I believe) with black markings..stars and bumper numbers
There is a picture of the truck here on the zone around 2007 that shows the truck if I can find it.
Serial # 19753
Date del. 1-68
Registration - 3G2080
http://www.m715zone.com/vb/picture.p...pictureid=1050
Thank you BMAC6026 and Nomad for your responses!
David, PM sent! THANK YOU EVERYONE!!
Looking for information on a m715. Where was it stationed, what did it do, was it in combat. How do I find this stuff out? The registration in the window if Massachusetts 2013.
Thankyou
Sorry but non of that information is available, there are no known ways to track where a vehicle was stationed or with which unit it served other than sanding down to find the last set of bumper markings. The military did not keep those records once the vehicle was surplussed, they were destroyed at that point. What I have found is a very limited data base of select vin #'s that allows me to match your vin# with the original hood registration numbers. That is the only info that the data base has.
Hello,
Glad to be here, have far more equations then answers. I recently bough m715#16257 and I'm m trying to find some history.
Pardon the repeat. Thanks for the information, so sand and see what numbers pop up. Thanks
great!!!:D
hood markings are 3F 3726 ,built 08-1967. vin #14863
3f 4772, 12293, 6/67
M715 #31424 10-68 3f5397
Attachment 3483
Attachment 3484
M715 #31323 10-68 9517658
Attachment 3492
Attachment 3493
22774 4/68 o3f73668
31208 10/68 387743
Attachment 3495
Attachment 3496
Attachment 3497
Attachment 3498
M725 SN 10701 reg. no. partially obliterated but almost certain it's 3f 0991. The top third? of last 4 is gone, but you can see it would have to be 0991.
M715 sn 21787 04-68 03e89068
M715 16361 3f8871 10/67
M726 10305 3-69 03b03769
M715 sn 17613 11-67
no hood markings as truck was repainted desert tan
dash markings above gauges is 68x34, curious to know what that means
also has a U.S. (illegible) Trooper decal on the windshield
2/68
VIN: 21183
Haven't found any registration numbers yet too many layers of paint....
Attachment 3677
Attachment 3678
Date Delivered: 1/68
S/N: 19793
Tail Gate Number 3G2169
Wench Truck
I have 2 to add: 30103 10/68 and 34218 01/69 both from dash data plates; the '68 also confirmed on the frame stamp. Interested to see how many are in use.
Thanks for adding to the data base.
Outer hood has too many coats of paint, but inside the hood is a note stating its been anti freeze protected to -20 degrees then in newer paint is 11 OCT 73, then in another shade of pain is a registration type number, 3F5367, my front bumber has stickers instead of paint, pass enger side: FRC 1 S GP with the drivers side it is barely legible with only a 3 being able to be made out on the very outer end. The tail gate is rather interesting also it has that hood number painted on the back then another coat of paint and some stickers with different numbers and letters i am still trying to sort out. If it helps my jeep came straight from the Yakima Wa military base training center, it was not auctioned off like most were but given to my local police force by the government
6/67 vin 12785
