Large, man you made my day! Just bought it! Thanks man!
If anyone needs one, here is another link, $15, free shipping. Great Christmas gift for your fellow M715 Zoner.
https://www.ebay.com/i/232193062927?chn=ps
https://digital-assets.opticatonline...6d3d556887.jpg
You guys tell me...if the reach is 1/2" for the Champion 633 (a.k.a. XML15Y, Link), that would make the overall length here 3", which is the same as the 2407, so we may have a winner winner chicken dinner if the heat range is equivalent.
Range on this plug is a 15. Anyone know if that is similar to the Autolite 2407? I am still hunting for a heat range cross over chart.
Hope it works for you!
I've looked through some literature I've saved on spark plugs and found that the Champion equivalent of the 633 (aka XML157) is the Autolite 2407. However, the heat range for the 2407 is listed as "H9".
Maybe a different heat range scale is used across spark plug manufactures?
Large, that is great. So I will call Autolite and see if they can help us understand heat range equivalents.
Check out this chart http://cruzrich.com/wp-content/uploa...conversion.jpg.
https://www.boschsparkplugs.net/lear...nversion-chart
At the link above, there is a section regarding Autolite with the following...
Autolite's numbering system does not have a standardized Heat Range identifier.
The last digit in an Autolite part number represents the Heat Range within a plug family.
For example, take the 254x plug series. Autolite has 2544, 2545 and 2546 available. 2544 is the coldest plug in that plug family, and 2546 is the hottest.
However, according to an Autolite reference chart, Autolite 86 has the same heat range as 2244 and Autolite 303 is a hotter plug than 2974.
Therefore, it is impossible to chart an Autolite Heat Range hierarchy, let alone a standardized comparison to other spark plug brands.
Given the 2407 is on the hotter end of the spectrum, and given that the 633/XML15Y is a 15 (hotter end of spectrum for Champion) I think we may have a winner, maybe. Appears that this plug (633/XML15Y) is the right length, the right reach, and the right heat range.
Anyone out there know much about the equivalents, or used this plug in a M715? I just ordered one from Amazon, and my 2344's are sitting over at NAPA, so I will do a side by side comparison when I have them both in hand, with photos and measurements.
{Note: Sincerely appreciate my Zone impromptu spark plug support group helping me along here in this quest...}
My plugs showed up today. See below for photos.
The silver one is the Champion 633 plug and is 2 5/16" inches to the seat. The darker plug is a 2344 Autolite for reference and is 2 1/2" to the seat.
633 is heat range 15. 2407 is H9. Hoping the 633 is a good replacement, as it is shorter like the 2407, and they are still available.
Hope this helps someone. RBhttps://uploads.tapatalk-cdn.com/201...d5e4241005.jpghttps://uploads.tapatalk-cdn.com/201...3e361d142c.jpghttps://uploads.tapatalk-cdn.com/201...315c3d6e9a.jpghttps://uploads.tapatalk-cdn.com/201...7b42d72b78.jpg
Sent from my SM-J700T using Tapatalk
The Champion plug is surely a much hotter plug because the center electrode is protruding farther, and the threaded portion is just a tad longer. I don't know the clearance during compression so I hope that the piston doesn't smack the electrodes.
Just a thought.
Here's a 2407; looks like it protrudes about the same as the 633. I guess we try the out and see what happens. I ordered 5 more last night. I will report back once I put them in.https://uploads.tapatalk-cdn.com/201...34a5277430.jpg
I have no idea regarding the history of the plugs that the truck has in it now, so maybe I just leave them alone? I guess once my nifty plug wire tool shows up, I can pull the plugs and have a look and see what I see. I will post those pictures up and you guys can weigh in. Ideally, they would be fine, and I can get more life out of them?
I thought changing plugs and filters and fluids would be a good way to get a baseline, and then figure out what the truck really needs from there.
Im asking same question about the Autolite AER72S, I pulled a plug from my motor, has champio nxmj-17 plugs in it & they have a shorter thread but a shank so long that you cant tighten the water proof coller over the top.
The Autolite AER72S shank is shorter ( im sure I could would have clearance to screw caps down) but concerned about piston clearance. cant find a manual that tells me a clearance over piston - the thread is longer by 1/4 on the Autolite AER72S.
Adding my recent experience to this thread-
I have a lot to update on my build thread (http://www.m715zone.com/vb/showthrea...d-update/page7) but - spoiler aleart - I got it running.
As part of that activity, I was having trouble getting it to start and idle well. Turns out that it was mostly due to choke setting, a trickly idle carb circuit, and crazy advanced ignition timing. Anyway, part of the troubleshooting involved replacing the plugs. They were old and rusty, so why not throw some money at the plugs?
As of mid-2022, there are very few choices for plugs. I read all the old threads on the 'Zone and any source for 2407, etc.. are dried up. Looks like most other vendors were out too, except for Memphis. So I ordered a set of 6 plugs from them.
What arrived are these:
Blue Crown SR8F18P
https://i.imgur.com/pz4S2Pll.jpg
https://i.imgur.com/mQezZnYl.jpg
Here it is compared to my original plug. The originals are too rusty to get a good number from them but they have the knurling like an Autolite of some sort.
https://i.imgur.com/s3OuEIal.jpg
You can see the reach is a lot longer and the electrode stick-out is much greater. The overall length of the Blue Crown is also shorter. I have no idea on the heat range but I suspect it is hotter than what was in the truck. I thought that would help with the poor start/idling and carbon build up. However, the reach was so much longer I was worried about clearance to the piston. So I put one plug in and rotated the engine by hand, and didn't "feel" anything, so I decided to install the set of six.
Partway through the install, I got to plug #5 and realized that Memphis had made a mistake, and sent qty 4 Blue Crown SR8F18P and qty 2 Autolite 2243.
Here are the Blue Crown next to Autolite 2243:
https://i.imgur.com/FpUcRt5l.jpg?1
https://i.imgur.com/g2CoA7vl.jpg?1
The blue crown electrode stick out is more than the Autolite, and the Blue Crown overall length is less.
I contacted Memphis, and they were suprised to see the Blue Crown. They thought all of their stock was the Autolites, since they have Autolite make those plugs for them in batches. They quickly sent me a couple of Blue Crowns to complete my engine.
As I mentioned earlier, the engine is now running, and as far as I can tell runs pretty well. I do have some dieseling at shutdown, which could be due to a hot combustion chamber (i.e. the long reach plugs?) or too fast of an idle. I will start with the idle speed reduction and see if that fixes it.
Anyway, if you are looking for plugs, it seems Memphis has them ($$) and you may even have a choice of the Blue Crown or the Autolite.
With the longer reach, as long as they dont hit which you have verified...they would raise the compression ratio some slight amount...being the stock motor is 7.5, it wont hurt a thing there!
