making stuff...and a little bit of progress
Regarding the generator field wire, I contacted Vintage Wiring of Maine, and they made a short jumper harness that will connect the new main harness to the existing wire on the generator. They were really nice to work with.
Other stuff:
After putting my steering column together, I realized that I was probably missing some type of plate at the firewall (see the red dotted line in the pic below)
https://i.imgur.com/a1a7Umxl.jpg
I don't know where it went but it is either in a mystery box of parts or it is long gone. Jeepdan confirmed that I was indeed missing something (Thanks Jeepdan!) and the manuals don't show it, so I had to fab something up. Based on the witness marks on the original foam gasket, and the shapes of the existing parts, I came up with something like this:
https://i.imgur.com/kLkFIq9l.jpg?1
https://i.imgur.com/SGeKzQal.jpg
https://i.imgur.com/m8q2ymPl.jpg
I also found some foam rubber on the internet and re-made the seal at the base of the steering column:
https://i.imgur.com/duxjvI1l.jpg?1
The same stupid kid (me) that lost that plate at the steering column also tossed the clip that holds the throttle cable at the firewall. So I had to make a new one of those too. I used the clip at the carburetor as a pattern. (I made it out of a stainless steel ruler that was conveniently at hand;)
https://i.imgur.com/00EnUEll.jpg
https://i.imgur.com/ScFW9ucl.jpg?1
Other random question - underhood marking?
Can anyone tell me what the text on the underside of the hood is supposed to say? Something along the lines of "Secure hood in open position with safety hook before ________" Maybe the blank is "servicing engine"? The pic below is of my hood before sand blasting it all away. I would like to know what it says so I can re-write it. Thanks!
https://i.imgur.com/MkIFOwWl.jpg
