The M715 motor uses a 3/16" spacer on the inside of the window frame. The shaft is 1-7/16". The M151 motor has a 2-1/4" shaft so needs a 13/16" spacer inside of the window frame to keep the outside shaft projection the same. Other then that, they are the identical. M151 motor is the one on the bottom.
http://img165.imageshack.us/img165/1088/wipersgq8.jpg
