Wow, that is incredible!! Are you sure that isn't just a shrunken 715??
Very nice work indeed. I know that takes a lot of patience and skill.
Thanks, guys! It almost took as long to build as my real M715. I would peck away at it an hour or so a night for quite a while. The shame of it all is that I have at least $150 in just the materials I used to build it. Between buying 3 complete models to cut apart and all the styrine stock.
Dave
Isn't it "Trident" that makes a very small model?
Fit and finish are supposedly not the best and its real small if I remember correctly, like 1/87th or something.
Yes, it is HO scale for use with model railroading. Which means that is about the size of a hot wheel car.
Dave
I think thats a full size 715 with a giant GI joe in the front seat. ;)
[QUOTE=Beast;61362]Thanks, guys! It almost took as long to build as my real M715. I would peck away at it an hour or so a night for quite a while. The shame of it all is that I have at least $150 in just the materials I used to build it. Between buying 3 complete models to cut apart and all the styrine stock.
QUOTE]
Hehehe......Even a representation of a 715 will still drain the wallet......
[QUOTE=randyscycle;61419]
Yep it was about the right ratio for the real one 1/18.
Dave
