ya will do, thanks jay dogg.
You would be much safer running some GOOD blocks for lift rather then those LONG shackles.
Agreed that the stock shackles are short and somewhat limiting. But the stock springs don't really flex enough to push the short shackles too much.
If you really want to keep those LOOONG shackles (I wouldn't), you really need to cross brace them. The easiest way is to just box them in. That would also help strengthen around the welds.
That strap down the middle will not to nearly as much compared to boxing them. And that is only a little more metal.
ya, i can do that. ill wip that up in a bit
