As I said, If Gonz (or anyone) can use it, I'll even help drag it out as far as I can to him! A 14-bolt rear won't do me much good until I have a matching front end to go with it! As it is now, it would just be taking up the space that the 35-spline Dana 60 I finally gave away is about to vacate!
Seriously!
You're right, I didn't really want it. Just had to pull your chain there! ;)
Well, the 14 bolt that I am hoping to buy is only one state away, and already at 4.56 gearing, lol. I'm sure there's some other Zoner in more need and closer, but I really do appreciate you offering up the axle even though Tim is trying to throw a monkey wrench into the deal!!- gonz
Need the NAPA numbers for the eldorado cable brackets (bracket, lever and return spring). These parts im still missing.
Btw. the swap is easy ... just use a big hammer to slam the studs out of the drums then youre faster ;)
