other than the std rubber rings what size valve stem seals would you need for a std SBC Head? i dont want the rubber Oring type..
Um, I assume you are talking about valve seals? Just do the intakes and the standard rubber rings work just fine when the guides and valve stems are still good. Once they go bad, no valve seal is going to keep the oil and smoke inside the engine.
