I borrowed a friends bender and double flare set. I built a couple rear axle brake lines for practice, as I didn't allow for the rear bump stops, oops. Anyway, I will be installing new to me backing plates, shoes, and wheel cylinders, thanks Dan. Then finish up my rear end bearings. I bought all my brake line stuff from Napa, they are military green in color and you can hand bend the lines, they have a coating on them. I suggest using the bender whenever possible. I'll be starting on my homemade brake lines shortly. The most difficult one will be the rear axle tube brake line, other than that piece of cake.
