fisherman :
Re: XL 11x16 Spare Tire Mounting
Post by fisherman on Aug 12, 2006, 11:22am
This is what I've found, First Tacoma My 69 j-3000 did have the rear crossmember in about if not the exact same location as the M-715. For sure as I still have that piece laying in the scrap metal pile. I'm sure Hummer tires mounted up will fit, not sure if they will fit a stock truck but pretty sure they will as they are not 38". Bob maybe you could try one. I'm surprised this hasn't been done yet. As for the swampers Over2land I'm sure they fit because they can't be a true 38" either. I am going to remove the round tube crossmember. And replace it with 2" by 3" 1/4 " wall rectangle tube steel moved forward until it is against the vertical piece of steel that keeps the channel frame seperated or reinforced. I will fully weld it and maybe gusset it. On the underside of the bed I will remove the spare tire stops, as there is plenty of room for spare to tuck up about 4" further, almost snug against bottom of the bed is what I want. This will allow me to fit a 39" tall tire I do believe. I will use a cable hoist spare tire system from probably a chevy truck. That way it will be easier to position that large tire and wheel as you crank it up there. I am going to do the frame modifications today and the bed modifications later when I reinstall the bed. I will photograph everything and post pictures so others can see my success or mistakes. Hopefully this will work out nicely. Fisherman
fisherman :
Post by fisherman on Aug 12, 2006, 4:35pm
OK, I just finished my rear round tube crossmember removal and fabrication of a new one. Thus allowing a 38" 11x16 XL tire to be mounted in the factory location. I believe a 40" tire will now fit, although I do not have one to try so only speculating there. The only thing I will have left to do is when i install the bed is to shorten or remove the two brackets underneath the bed allowing the spare tire to be tucked up tightly to the bed. I will also install a cable or chain spare tire asslembly so as to winch it straight up. I have on factory on my 93 chevy that looks good so I will probably try to get one like that or similiar. I have lots of pictures to post so bear with me while doing that. With the bed removed start to finish about 3 hours with all materials on hand. Pretty easy after I finally figured out what exactly had to be done in order for this to work properly. It took me a few days of looking and thinking to figure out what exactly I wanted to do. I'll try to start loading pictures soon. Fisherman
fisherman :
Post by fisherman on Aug 12, 2006, 4:59pm
http://img102.imageshack.us/img102/9...ures081qe1.jpgFirst shows the clearance of xl to pintle hitch nut.http://img102.imageshack.us/img102/7...ures082cv6.jpgThis shows the clearance of xl to tube crossmember I will be removing.http://img102.imageshack.us/img102/4...ures083fd6.jpgThis is the left side clearance for the xl.http://img102.imageshack.us/img102/9...ures084bh9.jpgThis is the right side clearance.http://img102.imageshack.us/img102/6...ures086be9.jpgBrace I added to keep everything from possible movement while torching out rivets of round crossmember.http://img102.imageshack.us/img102/1...ures087ht3.jpgFitting in 2" by 3" 1/4" thickness rectangle stock.http://img102.imageshack.us/img102/6...ures089qd5.jpgWelded in and ready for gussets.http://img102.imageshack.us/img102/2...ures092ow6.jpgLeft side gusset installed.Right side gusset installed.Gussets finished.Last three pictures show the new clearance for an Xl spare tire.I will post more pictures after I finish painting the frame and installing new leaf springs. Now everyone can do something similiar if they want their larger tires to fit underneath. Fisherman
luckypabst :
Post by luckypabst on Aug 12, 2006, 5:16pm
Good work man!
kwai :
Re: Xl spare tire mounting with pictures
Post by kwai on Aug 12, 2006, 7:32pm
I think even Bob would be proud of that work.
Nice job.
robertcowan :
Post by robertcowan on Aug 12, 2006, 8:34pm
TODD,
GOOD CLEAN WORK !!!!!!! YOU INSPIRED ME TO SEE IF HUMMER TIRES WILL FIT !!!!!
BOB
mikel :
Post by mikel on Aug 12, 2006, 8:41pm
Looking awesome!
robertcowan :
Post by robertcowan on Aug 12, 2006, 8:52pm
TODD,
I WAS THINKIN " LOOK OUT " ANYWAY---- ONCE YOU REMOVED THE RIVETS FROM THE STOCK X-MEMBER COULD YOU JUST SLIDE IT FORWARD ENOUGH TO CLEAR THE TIRE AND REDRILL THE HOLES AND BOLT IT IN ?
porkchop :
Post by porkchop on Aug 12, 2006, 9:49pm
Why couldn't you have posted this while I still had the bed off? Great work!
over2land :
Post by over2land on Aug 12, 2006, 10:05pm
Nice job man.
