tacomainoh :
Re: M725 project, your thoughts...
Post by tacomainoh on Jul 25, 2006, 11:10am
when you do the CTD swap, do it right and CUT THE FIREWALL. It will save you a lot of time/trouble trying to get stuff to fit right. Also be aware that you may need to go to an under-dash heater (a Flexalite Mojave or similar) if the turbo hits the heater box. I am doing a Chevy-Cummins swap and I need to mod the heater box on it, and there is more room there than in a Jeep.
4:10's are great, esp. w/a CTD. If you're going to drive it, that's a great combination. I"ve found that most people are recommending 3:55's w/the CTD.
wrecker :
Post by wrecker on Jul 25, 2006, 11:24am
With as much as you're using off the 89, have you considered a body swap? A little wheel base issues and firewall and body mounting fab might be easier than adapting everything to the 725 frame. Just a random thought.
alosix :
Post by alosix on Jul 25, 2006, 11:59am
Quote: <TABLE class=bordercolor cellSpacing=1 width="90%"><TBODY><TR><TD width="100%"><TABLE class=quote cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD width="100%">With as much as you're using off the 89, have you considered a body swap? A little wheel base issues and firewall and body mounting fab might be easier than adapting everything to the 725 frame. Just a random thought.</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Not a bad Idea, but we're picking up the 89 for a reasonable price mainly because its rusting apart. The drivetrain is good, but the rest isn't much.
Jason
