fredrader :
Re: Going nuts about my bolts...
Post by fredrader on Jul 5, 2006, 2:11pm
Take a cutoff wheel and cut a slot in the head of the screw so you can use a large regular screwdriver and heat ..It will come out..An impact driver is a life/screw saver when working with old rusty bolts and phillips screws.It keeps you from stripping out the X because you insert the bit in the screw and smack the driver with a hammer turning the screw .PB Blaster is an excellent penetrant and will help a lot..
grantshire :
Post by grantshire on Jul 5, 2006, 3:15pm
In a word (two actually) "screw knocker". Its an impact hammer attachment made by Brown Aircraft tools for loosening stuck rivits on airplanes. It fits in the hammer like a socket wrench attachment and has a 5/8" box end wrench attached to ots six sided shaft. The other end is setup for a 3/8" drive socket. It is the best tool in my tool box and will loosen screws, rivits, bolts, nuts, etc. when nothing else will. You loosen stuff by vibrating the screw/nut/bolt while putting pressure on the 5/8' wrench.
http://www.browntool.com/productsele...?productid=195
binfordm715 :
Post by binfordm715 on Jul 5, 2006, 3:47pm
Bob Villa recommends a Craftsman extractor tool for situations like maddawg's.
http://www.sears.com/sr/javasr/product.d....UseBVCookie=Yes
Anyone ever try one? Not sure if it would work in a situation where there's so much rust and corrosion that the bolt got ruined in the first place. Worth asking about though.
oilcan :
Post by oilcan on Jul 6, 2006, 5:56am
I have a set of those, Tim. Sometimes they work great, and sometimes they just drill a hole through the screw head.
