Re: Ford 300 swap, pros and cons.....
Post by barrman on Jun 26, 2006, 12:13pm
Yes, Chris did a great write up on the swap. I was very impressed with his workmanship and the fit of the engine. 13 mpg is pretty good too.
Post by binfordm715 on Jun 26, 2006, 12:15pm
No worries, Chris... Just figured a I6 swap to replace a I6 would have been easier than that! I've been leaning hard toward a SBC 350 swap, but since Fisherman and Saxon were touting the F*rd 300 pretty hard yesterday, I thought I'd open my mind to the possibility.
But there's still firewall clearance issues, plus a pusher-fan, which I'm not too keen on. For what benefit? Probably more torque, but not much more than a SBC, eh? And a bit less hp. Besides, I already have what's reported to be a sweet 465/205 setup just waiting for something to make it spin....
Also, your fabbing powers are significantly greater than mine! Hippie time or no, it would take me quite a bit longer to do what you did in a couple days!
[topic shift] Speaking of your fabbing powers, have you given any thought to a dual-tube roll bar for my bed?
Post by luckypabst on Jun 26, 2006, 12:27pm
Yes. I'm "between jobs" so that has me slightly stressed, more so than the average hippie but once I settle down I'm gonna play with some designs for the roll bar.
For the engine swap, it's hard to not recommend a GM swap - big block or small for the same reasons that everyone puts one in everything - it's just too easy and cheap for the return. I'm not keen on adapting to the stock tranny since you can buy a complete parts truck for what the adapter costs if you're diligent.
Post by davea on Jun 26, 2006, 3:58pm
If you were going to use a 300 6, what about sourcing one from a 3/4 or 1ton 2wd and scoring the zf 5 spd. as well?
Post by fisherman on Jun 26, 2006, 5:31pm
Tim, go in on a tubing bender with me and I'll weld and you can learn how to bend. Wouldn't want to disappoint Tacoma, sbc would be my choice over the 300. I would run either, just seems a bit easier to go sbc since you have some stuff lined up. Do I hear 383? Fisherman
Post by saxon on Jun 26, 2006, 5:47pm
Hey Tim I did mention the chev inline, say a 292, all your stuff from Tacoma will work, if you want, but with stock gears and the stock look, might as well retain the stock sound. I think the chev is slightly shorter, might be able to use pull fan. But bottom line is the small block is tried and trued. Dan
Post by davea on Jun 26, 2006, 5:55pm
A chevy 250 six fits well and Porky is doing a 292 swap.
Post by treepusher on Jun 26, 2006, 6:10pm
I had a chev 250 I-6 in the truck, way underpowered. For the weight of the truck, I would think the chev 350 as the minimum. I had a ford van work truck with the 300 I-6. Very torquey but still not like a higher revving SBC.
Post by luckypabst on Jun 26, 2006, 6:48pm
There ya go - I try to keep my 300 confined to 3K on the freeway. It'll pull happily to 4K+ but it ain't healthy with the notorious inline stroke.
With the GM deal, you can set up for a 350 and when the mood hits, just drop in a 454 or a 292 without much drama.
Post by pistolnut on Jun 26, 2006, 8:40pm
I've never done the swap, but I do have some experience with the 300. I had a '76 F-100 with that engine and it was bulletproof. Torquey but decent mileage. I swapped one into my truck from a junkyard (long story, I swapped out a good motor) that came from a UPS truck. It had a different cam, manual choke on the carb, and no emissions crapola. That engine had a bottom end forever, especially with the stock 3 on the tree. I think the 300 totally rocks--good economy, reliable, bulletproof. Having said that, I'm going SBC in my project truck. I hate Chevys; in my experience they don't last. I always have issues with valve seals. I've owned several and never been completely happy. I'm going that route because I have one, parts are very easily available, hop up parts are available, and they are pretty easy to work on. Also, they bolt pretty easily to the 3053A-heh heh heh.
