FE Convoy from NC/SC/VA area
Note to masses: If one would decide to chamfer the oil holes in the crank DO NOT get carried away AND don't chamfer it evenly the entire way around the hole. Chamfer it just lightly on the leading edge and heavier on the trailing side of the oil hole. ?? Chamfer it so that the larger chamfer will be behind the rotation and the oil will pulled out not pushed back in to the chamfer and hole like it would be if the leading side was chamfered big. Make sense? If you're sitting in the drivers seat, the crank rotates toward the drivers side so you'd want to chamfer the passenger side of the oiling holes.
