Thanks bill, I'm flat rate tech myself for the past 25 years .And was looking for the easy way out.
Bill ,my 715 has the metal gear and it eat the oil pump gear . just pulled it apart. I have new drive gear and front crank seal coming , were is the best place to get a pump or a rebuild kit for the pump?
Thanks.
You may check with Memphis Equip. I'm not sure if they would have one or not. So you have a steel crank gear rather than the bronze gear. Is the crank gear worn also or is the oil pump only worn?
yes, both steel oil pump drive gear and oil pump are shot. runs a little then jumped time big time. The FD that had the truck kept on replacing distributor for jumping time ( three times) them sold truck to me for a song:) does any body may a oil pump gear kit ,so I can press it together??
