Originally Posted by
rpgdeity
Yeah, nothing wrong with a Detroit (I hope to have a 4-53T one of these days...), but in all reality a '71 series Detroit is way too big for the 5/4 ton suspension. Plus parts plus transmission options, etc, you are really stepping into heavy duty commercial truck kinda stuff. Huge roadranger transmissions and the like.
Interesting fact, ALL the old Detroits are at least supercharged, they have to be in order to run properly since they are 2 stroke engines. Don't be fooled, the supercharger really doesn't boost the power output, its simply there to provide a constant positive pressure on the intake, otherwise the engine wouldn't run. Now the turbo versions are the Detroits you want to get because at idle the supercharger holds a little positive pressure, but then at higher RPMS the turbocharger puts out far more PSI boost than the supercharger and actually adds to overall performance. Basically at high RPMS the supercharger doesn't do anything and the turbo is doing the work for boost.
Our tender at the fire station is an old Freightliner with an 8V92T Detroit in it...talk about a big engine, 736 cubic inches. That sucker screams when it is wound up. Those engines also leak, no I should say that they slobber, lol. If a Detroit stops leaking, that means it is out of oil, lol.
