I swapped out the leaking manual gear today for the power gear
http://img.photobucket.com/albums/v1...ps6694b754.jpg
What pitman arm are you using?
George, did you have to do anything to the frame to get that to fit?
Do you have a new drive-train lined up yet?
Merry Christmas! I used a Lares 1106 box and a wagoneer arm from BJ's offroad.
Both were a direct bolt in. I just need to find a hose for for the hydroboost to go from 16x1.5 to 11/16 inverted flare.
Paul, I have everything out, and the whole engine compartment painted with rapco 24087. My sons transmission went out on his pickup, so I had to loan him $900 from the hobby fund. As soon as we are square, Ill be picking up a cummins of some sort. I have a line on 2 VE pumped engines with under 150,000 miles on each of them.
I am also thinking about a 4bt, but I was talking to Tim about that, and he said that they vibrate a lot more. Plus adapting an OD trans can be more expensive
I picked up this 6bt today. I can't wait for some warmer weather to get working
http://img.photobucket.com/albums/v1...ps5f9ae9de.jpg
Nice. What did the engine come out of? Older Dodge or something else?
Its an 89 non-i/c. The body rusted out and the guy pulled the engine for a conversion that never happened.
It has the external alternator voltage regulator and 3rd gen alt, and a magnetic crank trigger for an IssPro tach, other than that, its stock. New starter too
Is doesn't have the blowby tube, and there is just a slight haze of oil on the starter. The guy said that was 40k of driving. So it looks to have little blowby
I really havent done much. I did take the front clip off, sand blast the inside. chemically strip the outside, prime and paint.
Degreased and painted the engine:
http://img.photobucket.com/albums/v1...psdsfdujon.jpg
Have a new water pump, will put on a new lift pump, front and rear seals
Thanks Paul. This is the only pic I have of the progress, but I'll snap a few after it stops raining
http://img.photobucket.com/albums/v1...psyihavz6k.jpg
I am painting it back to stock color with rapco paint
