Originally Posted by
Roy
Pressure plate heights are different respectively to diaphram and finger-style.
Throw-out bearings are made in several different heights to correspond.
Clutch release arms also have different travle/release ratios. Centerline of t/o brg to centerline of pivot point and centerline of pivot point to the centerline of the engagement point measurements will help determine the ratio. It sounds like you might need an adjustable pivot. Sometimes the ratio of the release arm requires an adjustable pivot so that the arm does'nt interfere with the bellhousing during release travel.
