Next summer .... i would like to meet somes members of this board. Any meet near PA ??
Stock truck would work with a quad...this one needs to go BIG!!
Something along the lines of the gun trucks in Vietnam would be cool.
Some big updates ......
I was never satisfed with my current brake setup .... so here's the deal .... Hydroboost with a 2001 3500 HD master .... 1 9/16 of bore. Talk about brutal stopping power. But need to fabricated a spacer between my old hydroboost and the master but work perfectly. Always a problem .... cannot put back my air filter , so i will fabricate a new cold air intake with the filter in the right fender . Also the steering box was installed ... now it's easier to turn those big tires then a brand new car !!
http://www.rockcrawlerquebec.com/php...715/hydro1.JPG
http://www.rockcrawlerquebec.com/php...715/hydro3.JPG
Good deal on the brakes! Its nice to know you can stop fast if need be. Are you using the rockwell drums or pinion brakes?
still using the original drums at each wheel.
Good deal. I wonder if I could use that master cyl in place of a deuce master. Alot of guys are looking for a split system and those are rare. I may try to add a second air pack, so I could have a split system on the deuce. Do you know what the part # is for that master cyl?
Chevy master?
came from a 2001 3500 HD ... but have to fabricate a spacer between the master and hydroboost since it's was having a small gap.
