It was a precut kit from either greatlakes offroad or copperhead fab. You just bend the bottom into the "V", and weld it together
New tires in the house
http://img.photobucket.com/albums/v1...06541eca14.jpg
Are you going to leave the plactic on so they don't get dirty rolling around your shop?
Yea. I may not even take them off of the pallet :D
I like your old tires just fine myself....
But those look good too.
The new hummer tires dont have nearly the tread (wish they did), but I can them easily enough from several places. I got these from Trailworthy fab for $100.00 each. They said 75-95% tread, and these look to be about 80%
What did you do for the linkage from the pedal to the booster?
I've started my hydroboost planning this afternoon.
When I measure the old linkage from the brake pedal to the master cylinder in the original setup I measure approximately 4 inches from the center of the pedal stud to the mounting surface of the master cylinder.
When I measure the hydroboost setup it measures approximately 6 inches.
The rod in the hydroboost doesn't appear to be removable on my unit.
I suppose I could cut and weld it but wondered what others have done.
I got my hydroboost originally for a CJ7. Elliott (from here, ebay, FSJ.org and other forums) had a kit with everything.
I never got around to hydroboosting my CJ, so when I got the 715, I contacted him, and had a new bracket made to mount the HB to the firewall. Everything else was a direct bolt in. If you are looking for ease, contact Elliot, he can hook you up. Otherwise, there are places that make adjustable pushrods.
There are certain things that I am willing to whip out the tape measure and tools to fab. This was one of them that I was happy to purchase and bolt in.
I haven't had a lot of time lately, so the axles swap has gone slow. I am just waiting for a set of wheel bearings to come in, and I can button it up and bleed the brakes. It had all new joints, steering, bearings, etc. Hopefully it will out last me
http://img.photobucket.com/albums/v1...psc1062c74.jpg
My buddy tig'd the steering linkage, so that will be done today. I was shorted one wheel bearing, which I hope will be in today. If it does it will be ready except for bleeding the brakes
http://img.photobucket.com/albums/v1...ps4876495a.jpg
