so like i said before i used a water proof fuse box and then my friend gave me a audi a4 relay panel and a whole crap load of wire.... heh still not finished but here are some pics and also you get to see the black hole in my firewall the wires come out of lol :happy10:
http://img594.imageshack.us/img594/3682/39106747.jpg
Uploaded with ImageShack.us
http://img824.imageshack.us/img824/6522/88461512.jpg
http://img542.imageshack.us/img542/3374/48565798.jpg
http://img204.imageshack.us/img204/3435/44213667.jpg
also im using the old military switch for my head lights and fog lights
so my wheel bearings are fine its my kingpins that are SHOT!!!! lol... anybody know a place that might sell a kit for the kingpin you real seal and all that good stuff or do i have to do it the hard way and get everything seperate heh :p
Looks just like mine did a couple weeks ago! Are they "shot" or just loose? You can easily adjust the shims to take out any play and tighten them back up. That's all I did with mine, but the bearings and bushings were still in pretty good shape.
This place has what appears to be the correct parts
http://quad4x4.com/common%20front%20axle%20parts.htm
"QK4616 Large Knuckle Bearing & Bushing Kit"
http://www.bjsoffroad.com/CartGenie/prod-900.htm
http://www.m715zone.com/vb/showthread.php?t=7275&page=2
Looks like you have the same spindle nut socket that I got too...
Just out of curiosity, what size did you use? I got the 2 9/16 but it was a little big, so I think mine were 2 1/2". I've read on here that people have found both sizes, but the "factory" socket is 2-9/16".
mine were pretty bad the race's were all chewed up but the top mount was'nt to bad
can't seem to find the top brass bushing things on the kingpin knuckle...
it looked like they had them on the quad4x4 site. Maybe it would be worth giving them a call. I recall seeing a while back that some people do away with the bushing and just use another tapered roller bearing on top, since they are easier to come by. You could check to see if the races are the same, and try fitting one knuckle with both of your bearings. If it works, just get two bearings for each side and a new shim kit.
yeah i'll give them a call
this is another one im having a hard time finding.. alot of places are telling me they don't make it anymore
http://img836.imageshack.us/img836/5...downloadrb.jpg
if thats the metal ring with the rubber seal for the knuckle seal, it comes in the kit from BJ's that I linked above... The kit includes new outer plates and bolts, felt rings and the inner metal/rubber seal rings- everything you need to rebuild the knuckle ball seals.
