George, what throttle cable did you use? I am searching for one that will fit mine.
I used an 87 cable from a k2500/6.2. The pedal side was fine, but had to improvise on the IP side because the cable was too long. I used a set screw throttle cable clamp to make a loop.
I'll see if I can get a picture when I get come in a week (hunting, and they have cellular data service in the bottom 1/3 of Illinois this year!)
Don't worry about it George. I was thinking of just doing an LMC order for one and wanted to confirm what you had.
Thanks.
Sounds good Tim. Looks like good progress on yours
Axles are out of the truck and along with the tires, will be headed to Michigan to Jeeper's house this weekend.
New axles with 4.10's and 4 wheel disc brakes going under soon. Rear 14 bolt is done (stripped, painted, new calipers). I'll probably get that one in new years weekend.
Front dana 44 (temp for a few years, until I get other things done on the truck), needs the be stripped, painted, bearings packed, ball joints. That one will be a good long day in the garage... or a few short ones as time permits
Looks like progress is being made.
Are you going to do a spring over with the new axle?
No, staying stock Paul, just looking for some more street able gears, disc brakes to go with the hydro boost, and 8x6.5 wheel pattern.
Looking good Fling. I was there a while back. Looks like you will probably beat me done.
Thanks Troop. I just try to keep taking little bites out of it. Eventually it will get done
