Think it will fit in a USPS Flat Rate box???????
New steering parts ordered yesterday from Summit should have them on Monday. U-joint at the box, collapsible shaft and u-joint/vibration reducer on top at the column.
Will just have to turn the column shaft from 3/4" round to 3/4" DD like Brent showed in his post.
New hoses and I can mark power steering off the list. :D
Show some pictures and give me some summit numbers for the parts you ordered. I am getting ready to swap a 84 GW box into mine.
The later boxes (mine is out of a 72) have a different size/spline count. I will post mine when I am finished. For the later P/S box look at Brent's thread.
http://www.m715zone.com/vb/showthread.php?t=12635
Thanks. I am working today on putting my steering box in.
Got the clutch master cylinder mounted. It attaches to the pedal at a bolt I welded on. Put a stop on the floor so it does not max out.
http://img29.imageshack.us/img29/7910/dscn3784.jpg
http://img29.imageshack.us/img29/194/dscn3783.jpg
http://img29.imageshack.us/img29/7920/dscn3782.jpg
Once the p/s hoses get mounted and I solve my crank pulley issue, I will be ready for a test run of the motor.
Getting close:D
Got the steering parts last night. They will fit my application once I turn the stock column into a 3/4" DD.
My Summit part numbers are as follows:
BRG-014940 / U-joint / 3/4DD x 13/16-36 spline
BRG-034952 / U-joint & dampener / 3/4DD x 1DD
BRG-450024 / Collapsible shaft / 3/4DD x 1DD
Will post a pic when fininshed (hopefully tonight).
Pullies are on, belts are on, radiator is in, hoses are on.:D
P/S hoses, a few brake lines and a little wiring and she should be done. Hope to start her this weekend. Getting a little nervous now :eek:
I might be able to make it late Saturday afternoon or eve?
