the calculators that i have run the numbers through shows a truck with a real diameter of 41 inches and .73 final drive 69 MPH is 2100 rpm. it is really a close comparison to mine. 3000 rpm shows at about 97 MPH
Maybe the clutch is slipping??
If you find a California emmission 6.2, the Engine Speed Sensor is located on top of the vacuum pump. This sensor can be used to drive a quality gasoline engine tach with a few modifications. The entire process is detailed in the book by Lee Swanger titled "6.2 diesel engine vol II" available from thedieselpage.com. Since they're selling this, I'm sure they'd frown on me posting it in detail here, but it is not expensive.
