I guess I should have finished reading your thread and seen you put a stack. I would like to see some pics of how you ran it
i hav'nt run the exhaust yet still working on that.. i guess im gonna run a Y pipe somewhere but i might end up getting another stack...... a 3" body lift would make it easyier to run but im trying to avoid that cuz i like the way the truck sits now
so i was trying to put my stock fuel tank back in the truck and i have the straps but they are not long enough so im guessing im missing a part..... is there some kinda of bolt in bracket the straps hook to??? anyone...
you can see the attached brackets in this picture. the straps hook into these and then bolt to the bed
http://i853.photobucket.com/albums/a...girard/213.jpg
You just wanted to show off that rockwell with the new brakes :p not fair! anyway, as spgirard30 said, there are brackets on the bolt side. Nothing special, they just have a horizontal slot, like the mounts on the bed in front, and the strap goes into that (same as front) and then the bolt goes through a hole in the top and into the mounts on the bed. It's a [ shape bracket, straight with 90 degree bends.
lol thanks for the pic
im gonna fab some up tonight... :p
so here is what i did if anyone else runs into this problem.... i flatten out the back side of the straps and weld on some L shaped angle..... drilled a hole on the one side and ran some all thread between the old mount and the new one .... worked pretty good
here are some pics
http://img651.imageshack.us/img651/8849/89009200.jpg
Uploaded with ImageShack.us
http://img3.imageshack.us/img3/8900/69236702.jpg
Does this mean I get my gas can back? LM
lmao yeah you can have your gas can back :p
so after re sealing the tank running all new hose lines etc.... theres something inside the tank thats messed up....... guessing the pick up tube... i can only get the fuel filter i put in line to fill up a 1/4 of the way.......bblllaaahhhhhhhhh :( guess i'll be looking for some other fuel tank ...... schizer!!!!
