Cab Roof
The hard cab roof on my 68 M-715 appears to be flat. I want to remove it and replace with a canvas roof. I think the two bows have been modified. There isn't any curve to them and the rear and center bows are the same height as the front. When I see photos of the canvas tops installed it appears that the rear bow is taller. Does anyone have the dimensions of the bows?
Thanks.
There actually is a member that has made new bows in the past. I just can’t remember his name. Look at past threads about top bows and you will find him.
Top bow dimensions.
Still think Suby's post may be stickyworthy...
http://m715.com/vb/showthread.php?t=...light=top+bows
Good call. I just stuck it.
The rear bow is not any different than the front one...the 2 are interchangeable...the base that they sit on has the rear one set higher up than the front thus making it higher...
