XL spring-over picture
Post by foreverunstopable on Sept 1, 2006, 6:54pm
Hi guys. Does anyone know the height a sprung over 715 on stock axles with 11.00R16's would be from ground to cab bow at its highest point?
Re: XL spring-over picture
Post by tacomainoh on Sept 1, 2006, 8:10pm
about 8-9" higher than it is now, roughly. Figure this :
1/2 the difference in tire sizes+thickness of springs+1/2 the axle diameter. Off the top of my head that ought to give you your lift amount.
Post by brute4c on Sept 1, 2006, 9:41pm
Somewhere in that neighborhood....springovers give between 5 and 6 inches of lift and the tires are roughly 4 inches taller.....of which 2 inches actually raises the centerline of the axle....
So 7 to 8 inches I would guess....
Post by foreverunstopable on Sept 1, 2006, 9:43pm
Thanks! want to make sure it will fit in the garage.
