350 or 383
Post by gumball on Jul 31, 2006, 12:15pm
would like to know which engine will work best and why. Installing a nv4500 and remote np205, keeping original axles for now. Thanks
350 or 383
Re: 350 or 383
Post by barrman on Jul 31, 2006, 12:43pm
Do you have either version right now? Is money a concern?
A 350 crate engine is about the best value you can get. Call up your dealer and "pooof" you have a new engine with a warranty.
a 383 needs to be built or comes as an expensive crate. Either way, it will cost more. Yes, it makes more torque and hp. Power cost money, how much can you afford?
They are both well suited for this truck and fairly simple to install. It really comes down to what you want and how much you want to spend.
Re: 350 or 383
Post by tacomainoh on Jul 31, 2006, 4:30pm
I'd go w/the 350 just for longetivity and parts availability....
w/the original axles, you should have enough torque....
Re: 350 or 383
Post by wrecker on Aug 2, 2006, 8:50am
383 will require the externally balanced flywheel and harmonic balancer if I remember right. I have the 350 and the truck doesn't need the extra power with the stock gearing. I don't do any crazy wheeling though.
