Anyone know where I can get one? Also will need the bracket that mounts under the Alt. for it. What can I swap to?????? Thanks.
Which one? I found the smaller was discontinued. However comma,
I found that the hard to find PTO bearing was the very same bearing that 55 chev guys were using for a disc brake conversion. So when you have looked everywhere, try a hot rod shop. I even have a part number at home. I will try to find it tonight when I finally make it home.
It's the one that supports the shaft, by the motor mount. I know these things are hard to find, so was just wondering what I could use in it's place? Input? Thanks.
I got mine from AB linn. I thought you were talking about the smaller bearing inside the PTO. I still have my old support bearing if you want it. It has wear but is still usable. I do not have the metal flag that holds it. PM me if you want it.
BTW, the bearing is just about like a big heim joint center. I would bet one could be made.
Standby. I'll get in touch with ABLinn. Thanks for the info. Dave.
I was looking through the truck pic file and found this in the process.
http://img.photobucket.com/albums/v2...rriermount.jpg
That's the puppy! Good pic. Thanks.
